[gdal-dev] Writing to SQLite is very slow
Even Rouault even.rouault at mines-paris.org
Mon Jan 18 01:41:12 EST 2010
Roald,
You should try using transactions as suggested on IRC. This does make a lot of
difference for SQLite.
if 'lyr' is the Python object for your SQLite layer :
lyr.StartTransaction()
... insert features ....
lyr.CommitTransaction()
Best regards,
Even
Le Monday 18 January 2010 06:32:47 Roald de Wit, vous avez écrit :
> Hi list,
> Whilst trying to mimic ogr2ogr functionality in Python, I stumbled upon
> an issue with writing to SQLite: it works, but it's painfully slow
> (minutes instead of seconds).
> The link below points to an example that can be used for reproducing the
> behaviour:
> http://rdewit.pastebin.com/f73c9b3c0
> Outputting to ESRI Shapefile, or another CSV is very fast. It's only
> SQLite that seems to be slow.
> Any idea what I'm doing wrong?
> Regards, Roald
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
