[gdal-dev] Writing to SQLite is very slow
Mon Jan 18 09:23:49 EST 2010
Roald de Wit wrote:
> Hi Even,
> Thanks for this. Crschmidt *did* mention the transactions and I guess it
> would work if I were to create an empty layer and walk through the
> features one by one.
> I was hoping to use the 'CopyLayer' method of a DataSource (for
> simplicity's sake). It seems that you can provide options to it. Is
> there an option to tell it to use transactions?
Roald,
Would you mind filing a ticket on this?  I think the CopyLayer() method ought
to use transactions in a manner similar to ogr2ogr.
Best regards,
