[gdal-dev] No PROJ.4 translation for source SRS
Jamie Adams
jaadfoo at gmail.com
Tue Jan 19 12:10:24 EST 2010
There is no UTM zone specified in the input proj string. Is that the issue?
On Tue, Jan 19, 2010 at 5:36 AM, Smart, Gary <Gary.Smart at goodrich.com>wrote:
> I still can’t get to the bottom of this message – can anyone explain it…
> *ERROR 1: No PROJ.4 translation for source SRS, coordinate transformation
> initialization has failed*.
> I’m trying to convert the native coordinates in a file into WGS84
> lat/longs.
> However, when I create the OGRCoordinateTransformation (using the
> importFromWkt for input source and setWellKnownGeogCS(“WGS84”) for output) I
> get the above PROG.4 error.
> NOTE – if I use the proj.4 library directly, it seems possible to convert
> coords (e.g. converting WGS84 UTM to WGS84 LatLong):
> Proj4 code is something like…
> projIn = pj_init_plus(“+prof=utm +north +ellps=WGS84”);
> projOut = pj_init_plus(“+prof=latlong +ellps=WGS84”);
> pj_transform(projIn, projOut, blah blah);
> NOTE also that an old openEv executable I have, seems to be able to
> georeference these files fine.
> I am using Linux SLES10 SP2, gdal-svn-trunk-2009.12.14 and proj4-4.7.0-1.
> Any help welcome
> Gary
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100119/3e281468/attachment.html
