[gdal-dev] OGRFree(pszSrcWKT) can crash Matlab
Chaitanya kumar CH chaitanya.ch at gmail.com
Sat Jan 23 13:07:28 EST 2010
Joaquim,
You did change pszSrcWkt (
http://code.google.com/p/mirone/source/browse/trunk/mex/gdalwarp_mex.cpp#385
You should remove line 385 and move the line 386 to 330.
On Sat, Jan 23, 2010 at 11:17 PM, <jluis at ualg.pt> wrote:
> Quoting Even Rouault <even.rouault at mines-paris.org>:
>  Joaquim,
>> you don't provide enough code to really see what's wrong, but my guess is
>> that you misuse GDAL API.
> Even
> Quite possible the first and I was trying to summarize what happens
>> If you get pszSrcWKT, with
>> pszSrcWKT = GDALGetProjectionRef(hDS);
> No, I got it from oSrcSRS.exportToWkt( &pszSrcWKT );
> See lines 325 & 329 of
> Joaquim
>> The pszSrcWKT string is owned by the hDS object, so as soon as you destroy
>> the hDS object with GDALClose(), the pointer becomes invalid and points to
>> arbitrary data.
>> For the same reason, you should never free the string returned by
>> GDALGetProjectionRef() with OGRFree() or any other free() call.
>> See http://gdal.org/classGDALDataset.html :
>> GDALDataset::GetProjectionRef() :
>> returns:
>> a pointer to an internal reference string. It should not be altered, freed
>> or expected to last for long.
>> Best regards,
>> Even
>> Le Saturday 23 January 2010 16:04:58 jluis at ualg.pt, vous avez écrit :
>>> Hi,
>>> I have a serious crash in one of my Matlab MEXs caused by a call to
>>> OGRFree() with an argument of size one (possibly the  null terminator).
>>> This happens on OSX SL (64 bits) but not on Windows (where I still
>>> build at 32 bits)
>>> Here is, as far as I could trace it, what is happening (SVN version of
>>> the same age as GDAL1.7RC1)
>>> mexPrintf("---- %s\n%s\n", pszSrcWKT,pszDstWKT);
>>> That prints
>>> ---- GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],
>>> AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNI
>>> T["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","43
>>> 26"]] PROJCS["UTM Zone 29, Northern Hemisphere",GEOGCS["WGS
>>> 26"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PA
>>> RAMETER["central_meridian",-9],PARAMETER["scale_factor",0.9996],PARAMETER["f
>>> alse_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
>>> Next the code does:
>>>        GDALClose( hSrcDS );
>>> and now pszSrcWKT is empty. See
>>> ---- PROJCS["UTM Zone 29, Northern Hemisphere",GEOGCS["WGS
>>> If I make it print the size of pszSrcWKT  with strlen(pszSrcWKT) the
>>> answer is 1 and finally the MEX (and the entire MATLAB) crash on the
>>> call
>>> OGRFree(pszSrcWKT);
>>> Joaquim Luis
>>> This message was sent using IMP, the Internet Messaging Program.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100123/aeee37bd/attachment.html
