[gdal-dev] OGR projections - towgs84 issue
Even Rouault
even.rouault at mines-paris.org
Fri Jan 29 18:45:35 EST 2010
Steve,
when you specify a proj.4 string to GDAL/OGR, it doesn't keep it verbatim but
translates it into its internal SRS model (based on WKT format). When it must
pass a SRS back to proj.4, it translates from this model.
During this translation, if it detects an explicit datum known by PROJ.4, such
as NAD83, it just omits the towgs84 parameter.
+datum is a shortcut for specifying both +ellps and +towgs84. See this thread
http://n2.nabble.com/How-to-use-towgs84-td2393158.html where this was
debated.
So just remove the "+datum=NAD83" parameter. The +ellps and +towgs84 will then
be passed to PROJ.4.
Best regards,
Even
