[gdal-dev] Re: Error while using gdalwarp- Values become Zero
Monica Buescu monicabuescu1985 at gmail.com
Thu Jul 1 06:35:31 EDT 2010
Hi there
Regarding Hermann's answer:
> Could it be that the top right corner of final.tif is simply outside the
> extent of translate.tif and filled with 0, during warping?
What exacly that means? Because I have a 3x4 matrix and this means that I'm
loosing a pixel in top right...
I tested a different approach. Instead of gdal_translating I directly
gdal_warp it and I got the same error.
And I tested with other EPSG (WGS84 UTM 29N: 32629). And the same thing
happens. How can I avoid this?
Thanks
Monica
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100701/0ebec786/attachment.html
