[gdal-dev] Defining spatial resolution with gdalwarp
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jul 1 07:15:54 EDT 2010
Nikos,
If you are not sure what values to use for the resolution, you can try the
-ts option.
On Thu, Jul 1, 2010 at 4:20 PM, Nikos Dumakis <nikosdu1980 at gmail.com> wrote:
> Hi there
> I'm using gdalwarp do some reprojection of Globcover images from
> LatLong-WGS84 for a specific UTM EPSG. The thing is that gdalwarp's changed
> my original Spatial resolution. Shall I use -tr? if so, I just need to add
> the units? e.g. -tr 300 300 ?
> Thanks
> Nikos
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100701/533c8d94/attachment.html
