[gdal-dev] Re: C# bindings compile error VSE 2010
Tomas R
monshi at home.se
Thu Jul 1 10:13:49 EDT 2010
Set
@SET FrameworkVersion=v2.0.50727
in vcvars32.bat seems to work...
Yours
Tomas
Tomas R skrev 2010-07-01 13:01:
> Ok, will download that version.... done... and it compiled ok. As
> simple as that :)
> How about the target platform? Should be easy to set it to .Net2 but
> how? Now it compiles to .Net4.The version on dyndns is also targeted
> at .Net4 I notice.
> Thanks
> /tomas
> Tamas Szekeres skrev 2010-07-01 12:41:
>> Tomas,
>> You should use SWIG 1.3.39. The bindings haven't been tested with
>> SWIG 2.0.0. Upgrading SWIG always cause much of pain...
>> Best regards,
>> Tamas
>> 2010/7/1 Tomas R <monshi at home.se <mailto:monshi at home.se>>
>> Back again trying to compile gdal and the C# interface. This time
>> with VSE 2010, Gdal 1.7.2 and Swig 2.0.0 on a Vista32 machine
>> Gdal compiles fine, no problems, but the C# bindings fail with the
>> following error when using nmake:
>> csc /platform:x86 /target:library /out:gdal_csharp.dll
>> /r:ogr_csharp.dl
>> l gdal\*.cs AssemblyInfo.cs
>> Microsoft (R) Visual C# 2010 Compiler version 4.0.30319.1
>> Copyright (C) Microsoft Corporation. All rights reserved.
>> gdal\Band.cs(17,79): error CS0117: 'OSGeo.GDAL.GdalPINVOKE' does
>> not contain a
>> definition for 'BandUpcast'
>> gdal\Dataset.cs(17,82): error CS0117: 'OSGeo.GDAL.GdalPINVOKE'
>> does not contain
>> a definition for 'DatasetUpcast'
>> gdal\Driver.cs(17,81): error CS0117: 'OSGeo.GDAL.GdalPINVOKE' does
>> not contain a
>> definition for 'DriverUpcast'
>> NMAKE : fatal error U1077:
>> 'C:\Windows\Microsoft.NET\Framework\v4.0.30319\csc.EX
>> E' : return code '0x1'
>> Stop.
>> Since I am, and always will be, a newbie on C++ compilation I have
>> no idea what to do to fix it or if I can fix it.
>> And since I am asking here I throw in another Q - I want to target
>> the C# bindings to the .Net2 platform. How/where can I control
>> this via the commandline compiler, via the nmake command?
>> Yours
>> Tomas
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
