[gdal-dev] Bigtiff
    Axline, John
    John.Axline at ngc.com
    Thu Jul  1 13:12:17 EDT 2010
It looks like  WriteRaster [or some other component in the process] has
used all available memory and now has to do massive amounts of churning
between the last snippet of memory and your hard drive. Whether it's a
leak or a 'feature' of some library the author depended on is of course
moot. If you can kill un-needed processes and free some memory (e.g.
using Task Manager) you might get back into the 1 pct/hour range, but
probably would too-soon get back to glacial speed.
If you don't feel comfortable canceling tasks, you can lower their
priority.  But don't set your WriteRaster job (or anything) to realtime
priority - in that situation your mouse/keyboard becomes so
non-responsive the computer appears to be frozen.
One or more unrelated processes (e.g. an automatic virus scanner) might
also have become active, doing its chore inefficiently because of the
lack of resources.
You might also try the process on a 64-bit machine with a serious amount
of memory, and a local high-speed disk  or (RAID 0) disk array.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100701/0d9d276b/attachment.html
