[gdal-dev] Processing GRIB data to ASCII or text file
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jul 1 13:31:12 EDT 2010
Luisa,
You can try the "ASCII Gridded XYZ" format (http://gdal.org/frmt_xyz.html).
Just convert your GRIB files to the format "XYZ" using gdal_translate.
However, this is only available from GDAL 1.8. You will have to compile GDAL
trunk for this. (http://trac.osgeo.org/gdal/wiki/DownloadSource#Subversion)
On Thu, Jul 1, 2010 at 10:15 PM, Luisa Peña <luisapena1979 at gmail.com> wrote:
> Hi there
> I have several GRIB files and I wanted to do some statistical processing.
> To do so, I wanted to convert them to ASCII or text file. Is it possible
> using GDAL?
> Thanks
> Best regards,
> Luisa
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100701/f6fbd5c3/attachment.html
