[gdal-dev] ogr2ogr problem converting UK Ordnance Survey MasterMap
Martin Daly
Martin.Daly at cadcorp.com
Fri Jul 2 03:04:38 EDT 2010
> Here it is not only GDAL/OGR that has a problem! Currently, I know of no
> importer that can handle this construct, other than the tool (from Snowflake)
> used by OSGB to generate it - and there is also the question of onwards
> storage.
Not even close, I'm afraid.
There are plenty of tools to read (all parts of) OS MM:
http://www.ordnancesurvey.co.uk/oswebsite/products/osmastermap/information/technical/software.html
e.g. (an excellent one, at a very reasonable price...)
http://www.ordnancesurvey.co.uk/oswebsite/products/osmastermap/information/technical/software/cadcorp.html
Also, as far as I am aware, OS GB use in-house software to generate the data.
Martin
This email is confidential and may be privileged and should not be used, read
or copied by anyone who is not the original intended recipient. If you have
received this email in error please inform the sender and delete it from
your mailbox or any other storage mechanism. Unless specifically stated,
nothing in this email constitutes an offer by Cadcorp and Cadcorp does not
warrant that any information contained in this email is accurate.
Cadcorp cannot accept liability for any statements made which are clearly the
sender's own and not expressly made on behalf of Cadcorp or one of its agents.
Please rely on your own virus check. No responsibility is taken by Cadcorp
for any damage arising out of any bug or virus infection.
