[gdal-dev] Exception -- gdalJNI.AllRegister()
ahmet temiz ahmettemiz88 at gmail.com
Mon Jul 5 02:26:16 EDT 2010
Thank you
It is in Linux- Eclipse.
I rechecked library path in eclipse.
but I still receive this exception.
Is this problem likely to be arise from problematic jar ?
regards
2010/7/4 Even Rouault <even.rouault at mines-paris.org>:
> A quick search for UnsatisfiedLinkError in a search engine shows :
> http://java.sun.com/j2se/1.4.2/docs/api/java/lang/UnsatisfiedLinkError.html
> It means that the JVM cannot find the native libraries in the PATH. So make
> sure to have gdalXXX.dll (where XXX is the appropriate version number) and
> its dependencies, gdaljni.dll, ogrjni.dll, gdalconstjni.dll and osrjni.dll
> (or the equivalent .so if you're on Linux) in the PATH.
> Le Sunday 04 July 2010 18:30:58 ahmet temiz, vous avez écrit :
