[gdal-dev] Re: Writing non-ASCII characters to shapefile
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Mon Jul 5 07:53:03 EDT 2010
Hi Francis,
what does not portable mean? ArcMap handles UTF-8 fine, if the correct
encoding is written into the .cpg file. Recent shapelib should handle
this fine, too. If there is any problem with a specific GIS program, a
bug report for that GIS program might be the right thing to do.
Regards,
Peter
On Mon, 2010-07-05 at 19:18 +1000, Francis Markham wrote:
> At the bottom of this page, for one:
> http://resources.arcgis.com/content/kbase?fa=articleShow&d=21106
> But honestly I've found hard to find  information about this.  I'd be
> very happy to be corrected if this is not the case!
> Cheers,
> Francis
> On 5 July 2010 19:09, Hermann Peifer <peifer at gmx.eu> wrote:
> > Francis, you wrote:
> >> > I have heard that the use of UTF-8 in shapefiles is not portable.
> > Where did you hear this?
> > Regards, Hermann
> > On 03/07/2010 04:40, Francis Markham wrote:
> >> Hi there,
> >> I'm trying to write data from a Microsoft Excel .xls file into a
> >> shapefile, using OGR's Python bindings in Python 2.6.  This is going
> >> well, but I am having some problems when I try to write values that
> >> contain so-called "smart quotes".  Smart quotes are special
> >> characters, defined as characters 0x91 through 0x94 in Windows-1252 (
> >> see http://msdn.microsoft.com/en-au/goglobal/cc305145.aspx ).
> >> What is the best way to save this data to a shapefile using OGR?  I
> >> need the shapefile to be interoperable with other programs, including
> >> but not limited to ESRI products. While I assume I could simply
> >> translate these characters to standard ASCII, I would prefer not to if
> >> possible.  I also haven't tested the shapefiles with data from other
> >> character encodings.
> >> I have heard that the use of UTF-8 in shapefiles is not portable.  I
> >> am also aware that shapefile.cpg can store a shapefile's codepage.  I
> >> don't know how to put these pieces together to create a portable
> >> solution, however.
> >> Apologies if this is a newbie question, but I can't find answers on the
> >> web.
> >> Thanks,
> >> Francis Markham
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax  : +39 0473 069902
www  : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
