[gdal-dev] Re: Writing non-ASCII characters to shapefile
Hermann Peifer
peifer at gmx.eu
Tue Jul 6 04:31:37 EDT 2010
The .cpg files we generate through ArcGIS desktop contain the string: UTF-8
Some time ago, there was a mail on this list about problems in case of
conflicting information in the .cpg file compared to the Language Driver
ID (LDID) in the header of a dBASE file, see:
http://lists.osgeo.org/pipermail/gdal-dev/2010-May/024619.html
Hermann
On 06/07/2010 04:13, Francis Markham wrote:
> Okay, I will take that approach then. Thank you all for your help.
> What specific value should I write into the .cpg? The string '65001'
> or the string 'utf-8' or something else?
> -Francis
> On 5 July 2010 21:53, Peter Hopfgartner<peter.hopfgartner at r3-gis.com> wrote:
>> Hi Francis,
>> what does not portable mean? ArcMap handles UTF-8 fine, if the correct
>> encoding is written into the .cpg file. Recent shapelib should handle
>> this fine, too. If there is any problem with a specific GIS program, a
>> bug report for that GIS program might be the right thing to do.
>> Regards,
>> Peter
>> On Mon, 2010-07-05 at 19:18 +1000, Francis Markham wrote:
>>> At the bottom of this page, for one:
>>> http://resources.arcgis.com/content/kbase?fa=articleShow&d=21106
>>> But honestly I've found hard to find information about this. I'd be
>>> very happy to be corrected if this is not the case!
>>> Cheers,
>>> Francis
>>> On 5 July 2010 19:09, Hermann Peifer<peifer at gmx.eu> wrote:
>>>> Francis, you wrote:
>>>>>> I have heard that the use of UTF-8 in shapefiles is not portable.
>>>> Where did you hear this?
>>>> Regards, Hermann
>>>> On 03/07/2010 04:40, Francis Markham wrote:
>>>>> Hi there,
>>>>> I'm trying to write data from a Microsoft Excel .xls file into a
>>>>> shapefile, using OGR's Python bindings in Python 2.6. This is going
>>>>> well, but I am having some problems when I try to write values that
>>>>> contain so-called "smart quotes". Smart quotes are special
>>>>> characters, defined as characters 0x91 through 0x94 in Windows-1252 (
>>>>> see http://msdn.microsoft.com/en-au/goglobal/cc305145.aspx ).
>>>>> What is the best way to save this data to a shapefile using OGR? I
>>>>> need the shapefile to be interoperable with other programs, including
>>>>> but not limited to ESRI products. While I assume I could simply
>>>>> translate these characters to standard ASCII, I would prefer not to if
>>>>> possible. I also haven't tested the shapefiles with data from other
>>>>> character encodings.
>>>>> I have heard that the use of UTF-8 in shapefiles is not portable. I
>>>>> am also aware that shapefile.cpg can store a shapefile's codepage. I
>>>>> don't know how to put these pieces together to create a portable
>>>>> solution, however.
>>>>> Apologies if this is a newbie question, but I can't find answers on the
>>>>> web.
>>>>> Thanks,
>>>>> Francis Markham
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Dott. Peter Hopfgartner
>> R3 GIS Srl - GmbH
>> Via Johann Kravogl-Str. 2
>> I-39012 Meran/Merano (BZ)
>> Email: peter.hopfgartner at r3-gis.com
>> Tel. : +39 0473 494949
>> Fax : +39 0473 069902
>> www : http://www.r3-gis.com
>> XING : http://www.xing.com/go/invita/8917535
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100706/9f3db87b/attachment.html
