[gdal-dev] ogr2ogr problem converting UK Ordnance Survey MasterMap
Jez Walters
Jez.Walters at ipl.com
Mon Jul 12 05:20:32 EDT 2010
Even,
Please forgive my ignorance, but where can I get the code you are referring to? I've just looked at http://download.osgeo.org/gdal/ and I still see v1.7.2 as the latest version of the GDAL library.
I've tried using Subversion instead, like this:
svn checkout https://svn.osgeo.org/gdal/trunk gdal
, but I get the error message 'could not connect to server'! :-(
Apologies if I'm missing something obvious you!
Jez
____________________________________________________________
Jez Walters
Senior Consultant
direct phone: +44 (0)1225 475093
phone: +44 (0)1225 475000
fax: +44 (0)1225 444400
email: jez.walters at ipl.com
IPL Information Processing Limited
Eveleigh House, Grove Street, Bath, BA1 5LR, UK
www.ipl.com
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Sunday 11 July 2010 11:12
To: gdal-dev at lists.osgeo.org
Cc: Martin Daly; Peter J Halls; Jez Walters
Subject: Re: [gdal-dev] ogr2ogr problem converting UK Ordnance Survey MasterMap
Just to inform you that now that the NAS driver is in GDAL trunk, I've been
able to port its enhancements to the main GML driver. On the few samples I've
tested, OS Mastermap GML files seem to be read correctly now.
See http://trac.osgeo.org/gdal/ticket/3680
Le Friday 02 July 2010 09:04:38 Martin Daly, vous avez écrit :
> > Here it is not only GDAL/OGR that has a problem! Currently, I know
> > of no importer that can handle this construct, other than the tool (from
> > Snowflake) used by OSGB to generate it - and there is also the question
> > of onwards storage.
> Not even close, I'm afraid.
> There are plenty of tools to read (all parts of) OS MM:
> http://www.ordnancesurvey.co.uk/oswebsite/products/osmastermap/information/
>technical/software.html
> e.g. (an excellent one, at a very reasonable price...)
>technical/software/cadcorp.html
> Also, as far as I am aware, OS GB use in-house software to generate the
> data.
> Martin
>* This email is confidential and may be privileged and should not be used,
> read or copied by anyone who is not the original intended recipient. If
> you have received this email in error please inform the sender and delete
> it from your mailbox or any other storage mechanism. Unless specifically
> stated, nothing in this email constitutes an offer by Cadcorp and Cadcorp
> does not warrant that any information contained in this email is accurate.
> Cadcorp cannot accept liability for any statements made which are clearly
> the sender's own and not expressly made on behalf of Cadcorp or one of its
> agents. Please rely on your own virus check. No responsibility is taken by
> Cadcorp for any damage arising out of any bug or virus infection.
> gdal-dev mailing list
The information transmitted is intended only for the person
or entity to which it is addressed and may contain
confidential and/or privileged material. If you are not the
addressee, any disclosure, reproduction, copying,
distribution, or other dissemination or use of this
communication is strictly prohibited. If you have received
this transmission in error please notify the sender
immediately and then delete this email.
Any representations or commitments expressed in this email
are subject to contract.
This message has been scanned for viruses and dangerous
content. However, it is essential that the recipient also
checks this message using commercially available mail
scanning and anti-virus software. IPL Information Processing
Limited accepts no liability for any loss or damage resulting
from any virus or other dangerous content in this message.
IPL Information Processing Limited is registered in England
and Wales under company registration number 1418818.
Registration took place at Cardiff on 10 May 1979. IPL
Information Processing Limited's registered office and
normal place of business is Eveleigh House, Grove Street,
Bath, BA1 5LR, United Kingdom. IPL is also registered for
Value Added Tax (VAT) under registration number GB 601 2931 83.
