[gdal-dev] GeoRaster: problem updating on predefined existing
table
Pasta Bolognese
pasta.bolognese at gmail.com
Tue Jul 13 04:18:44 EDT 2010
that is a good news ! so now I need just to wait that the OSGeo4W
team add the gdal17-oracle package.
thanks !
On Tue, Jul 13, 2010 at 2:11 AM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
> I just noticed from your ticket [http://trac.osgeo.org/gdal/ticket/3681] that you are using GDAL 1.6.3. Right?
> A lot has changed since then. I run the same sequence of options as you and everything works fine in GDAL 1.8dev.
> I believe it should work fine with the current released version too. GDAL 1.7.2.
> Please update it and try again.
> Regards.
>> -------Original Message-------
>> From: Pasta Bolognese <pasta.bolognese at gmail.com>
>> To: Ivan Lucena <ivan.lucena at pmldnet.com>
>> Cc: gdal-dev at lists.osgeo.org
>> Subject: Re: [gdal-dev] GeoRaster: problem updating on predefined existing table
>> Sent: Jul 12 '10 09:59
>> doing more experiments it results that the error is given ONLY when
>> the schema is given.
>> gdal_translate -of georaster c:\tmp\map.png ^
>> georaster:geoserver/geoserver,MFDEVDB,GEOSERVER.PASTA
>> _RASTERS,raster ^
>> -co "INSERT=VALUES(SDO_GEOR.INIT('pasta_rdt_01'))"
>> It is using the table GEOSERVER.PASTA _RASTERS. It would work only
>> once. After that it would give the same error ORA-00955)
>> georaster:geoserver/geoserver,MFDEVDB,PASTA _RASTERS,raster ^
>> It is using the table PASTA _RASTERSThis would work all the time..
>> Is it working as expected ?
>> On Mon, Jul 12, 2010 at 2:54 PM, Pasta Bolognese
>> <pasta.bolognese at gmail.com> wrote:
>> >> > C:\>gdal_translate -of georaster c:\tmp\map.png
>> >> > and it works well. Then I've imported another immage using the same
>> >> > command and it worked well too !
>> >> Note that you didn't specify table & column so a table named "GDAL_IMPORT", column "RASTER" was created for you as default.
>> > exactly
>> >> > Then I have decided to use a predefined table.... and here the problems:
>> >> > georaster:geoserver/geoserver,MFDEVDB,geoserver.pasta
>> >> This command is missing the column name after "schema.table" so it is assuming column name "RASTER" as default. Does the table "pasta" existed before that command?
>> > exactly. The table PASTA is created automatically by the command itself.
>> >> > Input file size is 1014, 863
>> >> > 0...10...20...30...40...50...60...70...80...90...100 - done.
>> >> > Ouput dataset: (georaster:geoserver,geoserver,MFDEVDB,RDT_33$,33) on
>> >> > PASTA,RASTER
>> > at this point the table is created by GDAL
>> >> > ERROR 1: ORA-00955: name is already used by an existing object
>> >> > ORA-06512: at line 10
>> >> > ERROR 1: Create Table Error!
>> >> Again, this command is missing the column name too, so I believe it is trying to re-create the table "Pasta" with column "RASTER". Whatever is happening is caused by the error on the command.
>> > At this point GDAL should add a new line to the same table....
>> > infact even giving the table name and the column name: (again, the
>> > table is created automatically by GDAL)
>> > georaster:geoserver/geoserver,MFDEVDB,geoserver.pasta,raster
>> > Ouput dataset: (georaster:geoserver,geoserver,MFDEVDB,RDT_42$,42) on
>> > PASTA,RASTER
