[gdal-dev] MEM Datasets
James Meyer
jamesm at lantic.net
Tue Jul 13 08:29:23 EDT 2010
Hi
Actually I did call it.
Sorry I just didn't include it in the code because it was much earlier
in the program.
However after some playing around, it seems that the error only occurs
IF I did a write to the MEM dataset. (Although it occurs WHEN I close it).
The code I am using to test is below line-for-line exact. I basically
read from an existing dataset (known to be GDT_Byte) into the in-memory
dataset.
It seems like some sort of buffer overflow, because if I delete the last
two lines (that frees the buffers) I get a long "stack smash detected"
printout in stead of a segmenation fault.
Can you see anything I am doing wrong?
Thanks
GDALAllRegister();
char filename[255];
int sizey = 100;
int sizex = 100;
int datasize = sizex * sizey * (GDALGetDataTypeSize(GDT_Byte) / 8);
void* data = malloc(datasize);
sprintf(filename,
"MEM:::DATAPOINTER=%p,PIXELS=%d,LINES=%d,BANDS=%d,DATATYPE=%s",
&data, 100, 100, 1, GDALGetDataTypeName(GDT_Byte));
GDALDatasetH dst = GDALOpen(filename,GA_Update);
GDALDataset* dest = (GDALDataset*) dst;
GDALRasterBand * destBand = dest->GetRasterBand(1);
GDALDataset* source = (GDALDataset*) GDALOpen("images/ref.pix",
GA_ReadOnly);
GDALRasterBand* sourceBand = source->GetRasterBand(1);
if (! dest || !source )
printf("Failed to open Dataset");
void* buffer = malloc(sizex*sizey); //For byte data type
if (CE_Failure == sourceBand->RasterIO(GF_Read, 0, 0,sizex, sizey,
buffer, sizex, sizey, GDT_Byte ,0,0))
printf("READ FAILED");
if (CE_Failure ==destBand->RasterIO(GF_Write, 0, 0,sizex, sizey,
buffer, sizex, sizey, GDT_Byte,0,0 ))
printf("WRITE FAILED");
printf("Releasing Resources\n");
GDALClose(dst);
free(data);
free(buffer);
On 13/07/2010 13:37, Chaitanya kumar CH wrote:
> James,
> You forgot to call GDALAllRegister() before opening the dataset. Then
> you will not get a NULL with GDALOpen().
> http://www.gdal.org/gdal_tutorial.html
> On Tue, Jul 13, 2010 at 3:40 PM, James Meyer <jamesm at lantic.net
> <mailto:jamesm at lantic.net>> wrote:
> Hi
> I am trying to use MEM (In-memory) datasets with GDAL.
> However, on trying to close the dataset I get a segmentation fault.
> The dataset is created successfully. The handle returned is valid
> and I am able to read and write to it.
> Am I not supposed to try and close the handle or am I doing
> something else wrong?
> The code is as follows:
> char filename[255];
> int datasize = 100 * 100 * (GDALGetDataTypeSize(GDT_Byte) / 8);
> sprintf(filename,
> if (! dest )
> GDALClose(dst); //This fails
> free(data);
> Thanks
> James
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
