[gdal-dev] ogrtindex take only one feature from a layer
easyl
thlin.box at gmail.com
Wed Jul 14 04:13:14 EDT 2010
I tried ogrtindex on two shapefiles.
Each source shapefile has more than one "Feature Count" in a Polygon layer.
after running "ogrtindex index.shp src/*.shp"
I got index.shp with only two features (one from each source shapefile).
And the Polygon is not the same from the source data.
How exactly should and how I use orgtindex?
> ogrinfo index.shp index
INFO: Open of `index.shp'
using driver `ESRI Shapefile' successful.
Layer name: index
Geometry: Polygon
Feature Count: 2
Extent: (7.140330, 53.137500) - (8.255000, 53.652667)
Layer SRS WKT:
(unknown)
OGRFeature(index):0
LOCATION (String) = src/1.shp,0
POLYGON ((7.14033 53.621002500000003,7.14033 53.6526675,7.165335
53.6526675,7.165335 53.621002500000003,7.14033 53.621002500000003))
OGRFeature(index):1
LOCATION (String) = src/2.shp,0
POLYGON ((8.223832399999999 53.137500000000003,8.223832399999999
53.145000000000003,8.255 53.145000000000003,8.255
53.137500000000003,8.223832399999999 53.137500000000003))
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ogrtindex-take-only-one-feature-from-a-layer-tp5291516p5291516.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
