[gdal-dev] S-57 New Objects
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Jul 15 06:50:47 EDT 2010
Alex,
Refer to the fourth paragraph in http://www.gdal.org/ogr/drv_s57.html on how
to set a directory with your lists.
Also see http://home.gdal.org/projects/s57/index.html
On Thu, Jul 15, 2010 at 2:34 PM, kasej <alexbenke at gmail.com> wrote:
> Dear All,
> for my project I want to use the OGR-Library. OGR can read S-57 files,
> but only with predefined Objects and Attributens. I want to extend the
> Object- and Attribute list, and add my own Objects and Attributes.
> My question is: Which files should I change in the source of
> OGR-Lybrary. Are there only *.csv - files with Objects and Attributes,
> or should I change also something in the source code?
> Best Regards, Alex
> http://osgeo-org.1803224.n2.nabble.com/S-57-New-Objects-tp5296524p5296524.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100715/a6570790/attachment.html
