[gdal-dev] Need some help with projections
Paul Meems bontepaarden at gmail.com
Thu Jul 15 15:18:06 EDT 2010
Thanks Jean-Claude,
I was using EPSG:900913 for the OSM tiles and Googled about it looking for
the +towgs84 parameter but couldn't find anything.
I did find several posts about EPSG:3785 being the same as EPSG:900913 and
that one does have the +towgs84 parameter.
Should I use that proj4 string instead?
+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
+towgs84=0,0,0,0,0,0,0 +units=m +no_defs
And how about the custom projection? Do you have any idea how to create a
proj4 style string from that?
Thanks,
Paul
2010/7/14 Jean-Claude REPETTO <jrepetto at free.fr>
> Hi,
> On 07/14/10 11:54, Paul Meems wrote:
>> I'm using this proj4 string for the OSM tiles:
>> +proj=merc +lon_0=0 +lat_ts=0 +x_0=0 +y_0=0 +a=6378137 +b=6378137
>> +units=m +no_defs
> This one is not correct if you want to do a datum transformation : the
> +towgs84 parameter is missing.
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100715/d45940f9/attachment.html
