[gdal-dev] Tkl/Tk files after running script through py2exe
Simon Lyngby Kokkendorff
silyko at gmail.com
Wed Jul 21 01:28:33 EDT 2010
Hi Rudi,
py2exe includes a lot of things into the distribution by default, so
you'll need to extend the "excludes" in your options in the setup script to
get a smaller distribution, see
http://www.py2exe.org/index.cgi/GeneralTipsAndTricks. I've been using gdal
with py2exe, and I guess that if you don't need large libraries like e.g.
matplotlib or wx in your distribution, you should be able to get the size
down to a few (less than 10) MB.
Cheers,
Simon
On Tue, Jul 20, 2010 at 1:54 PM, Rudi von Staden <rudivs at gmail.com> wrote:
> Hi all,
> I've created a small Python script that reads a set of points from a CSV
> file, calculates the area of the outer hull of the points, and writes the
> result to a text file. I would like to call the script from an Access
> database. Since I can't guarantee that the users will have Python, I ran the
> script through py2exe.
> 1) The resulting distribution folder includes Tcl/Tk files and folders. I
> can only guess that these are used by GDAL in some way - are they required?
> 2) The package is also surprisingly large for such a simple function -
> nearly 30MB. I suppose that's to be expected, but is there a way to bring
> down the footprint, short of translating to C++?
> Thanks,
> Rudi
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100721/2a9986dd/attachment.html
