[gdal-dev] ogr2ogr OCI: problem loading shapes
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Jul 22 10:14:35 EDT 2010
Hi All
sebas at SeansPC:~/shapes/Fluvial_Extents$ time ogr2ogr -f OCI
OCI:geoserver/geoserver at mfproduk_11g: FluvialUD04Q100Outline.shp -lco
srid=81989 -lco PRECISION=NO -progress
0...10...20...30...40...50...60...70...80...90...100 - done.
ERROR 1: ORA-29855: error occurred in the execution of ODCIINDEXCREATE
routine
ORA-13249: internal error in Spatial index: [mdidxrbd]
ORA-13249: Error in Spatial index: index build failed
ORA-13249: Error in spatial index: [mdrcrtxfergm]
ORA-13249: Error in spatial index: [mdpridxtxfergm]
ORA-13200: internal error [ROWID:AAASLwAAFAAA5AxAAC] in spatial indexing.
ORA-13206: internal error [] while creating the spatial index
ORA-13034: Invalid data in the SDO_ORDINATE_ARRAY in SDO_GEOMETRY object
ORA-06512: at "MDSYS.SDO_INDEX_METHOD_10I", line 10
in CREATE INDEX "OSI_16180" ON FLUVIALUD04Q100OUTLINE("ORA_GEOMETRY")
INDEXTYPE IS MDSYS.SPATIAL_INDEX
real 1m10.377s
user 0m27.680s
sys 0m0.710s
sebas at SeansPC:~/shapes/Fluvial_Extents$ ogrinfo FluvialUD04Q100Outline.shp
INFO: Open of `FluvialUD04Q100Outline.shp'
using driver `ESRI Shapefile' successful.
1: FluvialUD04Q100Outline (Polygon)
sebas at SeansPC:~/shapes/Fluvial_Extents$ ogrinfo --version
GDAL 1.7.2, released 2010/04/23
ideas ?
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100722/cbb581d0/attachment.html
