[gdal-dev] ogr2ogr OCI: problem loading shapes
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Jul 22 10:36:33 EDT 2010
Hi Ivan,
I've tried again without the ":"... and the problem is still there...
sebas at SeansPC:~/shapes/Fluvial_Extents$ time ogr2ogr -f OCI
OCI:geoserver/geoserver at mfproduk_11g FluvialUD04Q75Outline.shp -lco
srid=81989 -lco PRECISION=NO -progress
0...10...20...30...40...50...60...70...80...90...100 - done.
ERROR 1: ORA-29855: error occurred in the execution of ODCIINDEXCREATE
routine
ORA-13249: internal error in Spatial index: [mdidxrbd]
ORA-13249: Error in Spatial index: index build failed
ORA-13249: Error in spatial index: [mdrcrtxfergm]
ORA-13249: Error in spatial index: [mdpridxtxfergm]
ORA-13200: internal error [ROWID:AAASMIAAFAABEt0AAD] in spatial indexing.
ORA-13206: internal error [] while creating the spatial index
ORA-13034: Invalid data in the SDO_ORDINATE_ARRAY in SDO_GEOMETRY object
ORA-06512: at "MDSYS.SDO_INDEX_METHOD_10I", line 10
in CREATE INDEX "OSI_15101" ON FLUVIALUD04Q75OUTLINE("ORA_GEOMETRY")
INDEXTYPE IS MDSYS.SPATIAL_INDEX
real 1m25.698s
user 0m26.660s
sys 0m0.580s
regards
On Thu, Jul 22, 2010 at 3:24 PM, Ivan Lucena <ivan.lucena at pmldnet.com>wrote:
> Hi Sebastian,
> Did you intend to enter table name after
> "OCI:geoserver/geoserver at mfproduk_11g:"?
> I am asking that because there is a ":" at the end but with no information
> after that.
> I don't know if that would affect the OCI driver.
> Regards,
> Ivan
> > -------Original Message-------
> > From: Sebastian E. Ovide <sebastian.ovide at gmail.com>
> > To: gdal-dev at lists.osgeo.org
> > Subject: [gdal-dev] ogr2ogr OCI: problem loading shapes
> > Sent: Jul 22 '10 09:14
> > Hi All
> > OCI:geoserver/geoserver at mfproduk_11g: FluvialUD04Q100Outline.shp -lco
> > routine
> > ORA-13200: internal error [ROWID:AAASLwAAFAAA5AxAAC] in spatial
> indexing.
> > in CREATE INDEX "OSI_16180" ON FLUVIALUD04Q100OUTLINE("ORA_GEOMETRY")
> > real 1m10.377s
> > user 0m27.680s
> > sys 0m0.710s
> > sebas at SeansPC:~/shapes/Fluvial_Extents$ ogrinfo
> > INFO: Open of `FluvialUD04Q100Outline.shp'
> > using driver `ESRI Shapefile' successful.
> > 1: FluvialUD04Q100Outline (Polygon)
> > sebas at SeansPC:~/shapes/Fluvial_Extents$ ogrinfo --version
> > GDAL 1.7.2, released 2010/04/23
> > ideas ?
> > Sebastian E. Ovide
> > gdal-dev mailing list
> > [LINK: compose.php?to=gdal-dev at lists.osgeo.org]
> > [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100722/fb470e67/attachment.html
