[gdal-dev] Re: ogr2ogr OCI: problem loading shapes
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Jul 26 08:11:41 EDT 2010
http://gdal.org/ogr/drv_oci.html says:
Layer Creation Options
DIM: This may be set to 2 or 3 to force the dimension of the created layer. If not set 3 is used by default.
Have you tried that?
-Jukka-
Sebastian E. Ovide wrote:
On Fri, Jul 23, 2010 at 7:38 PM, Jukka Rahkonen
<jukka.rahkonen at mmmtike.fi>wrote:
> Validate geometries
validating geometries it came out: ORA-54668: a 2D SRID cannot be used with
a 3D geometry
therefore I've used the option -nlt POINT as suggested
http://osgeo-org.1803224.n2.nabble.com/howto-flattening-of-3D-shapefiles-td3038433.html
but I still get the same ORA-54668 validation error...
any ideas ?
Sebastian E. Ovide
