[gdal-dev] Python Bindings
Jeff Hamann jeff.d.hamann at gmail.com
Mon Jul 26 18:35:56 EDT 2010
I've built GDAL/OGR (1.7.2) with the following ./configure options
$ ./configure \
 CC="gcc -arch i386" \
 CXX="g++ -arch i386" \
 OBJC="gcc -arch i386" \
 F77="gfortran -arch i386" \
 FC="gfortran -arch i386" \
  --with-pg=/usr/local/pgsql/bin/pg_config \
  --without-macosx-framework \
  --without-sqlite3 \
  --with-python
Even though I run on a mac, I really don't want to build with the framework.
When I attempt to run a simple Python script:
#! /usr/bin/env python
from osgeo import gdal
I get the following:
Jeff-Hamanns-MacBook-Pro:scripts hamannj$ python pytest.py
  File "pytest.py", line 2, in <module>
  File "/Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/__init__.py", line 21, in <module>
    _gdal = swig_import_helper()
  File "/Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/__init__.py", line 17, in swig_import_helper
    _mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: dlopen(/Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/_gdal.so, 2): Symbol not found: _CPLDefaultErrorHandler
  Referenced from: /Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/_gdal.so
  Expected in: flat namespace
 in /Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/_gdal.so
I know *nothing* about python.
There are a bunch of these statements:
from osgeo import osr
import osgeo.gdalconst as gdalc
from optparse import OptionParser, OptionGroup
import binascii
import glob
import math
import numpy
import os
import sys
in the gdal2wktraster.py file that I eventually want to run, but I don't know enough about python to diagnose, debug, and correct these problems.
Is this a python binding problem with gdal/ogr?
When I ./configured gdal/ogr: I got the following results:
GDAL is now configured for i386-apple-darwin10.4.0
  Installation directory:    /usr/local
  C compiler:                gcc -arch i386  -g -O2
  C++ compiler:              g++ -arch i386  -g -O2
  LIBTOOL support:           yes
  LIBZ support:              external
  GRASS support:             no
  CFITSIO support:           no
  PCRaster support:          internal
  NetCDF support:            yes
  LIBPNG support:            internal
  LIBTIFF support:           internal (BigTIFF=yes)
  LIBGEOTIFF support:        internal
  LIBJPEG support:           internal
  8/12 bit JPEG TIFF:        yes
  LIBGIF support:            internal
  OGDI support:              no
  HDF4 support:              no
  HDF5 support:              no
  Kakadu support:            no
  JasPer support:            no
  ECW support:               no
  MrSID support:             no
  MSG support:               no
  GRIB support:              yes
  EPSILON support:           no
  cURL support (wms/wcs/...):yes
  PostgreSQL support:        yes
  MySQL support:             no
  Ingres support:            no
  Xerces-C support:          no
  NAS support:               no
  Expat support:             yes
  ODBC support:              no
  PGeo support:              no
  PCIDSK support:            internal
  OCI support:               no
  GEORASTER support:         no
  SDE support:               no
  DODS support:              no
  SQLite support:            no
  SpatiaLite support:        no
  DWGdirect support          no
  INFORMIX DataBlade support:no
  GEOS support:              yes
  VFK support:               yes
  Mac OS X Framework :       no
  SWIG Bindings:          python
  Statically link PROJ.4:    no
  enable OGR building:       yes
  enable pthread support:    no
  hide internal symbols:     no
Jeff-Hamanns-MacBook-Pro:gdal-1.7.2 hamannj$
Jeff Hamann
