[gdal-dev] Chaning GML geometry source by GFS fails.
Ralf Suhr
Ralf.Suhr at itc-halle.de
Tue Jul 27 13:04:07 EDT 2010
Hello list,
I want to import a gml with two defined geometries. As I read ogr2ogr will
always use the last geometry.
I added one line to the gfs file to change the geometry source. But ogr2ogr
ignore this. gdal is from svn revision 198??
the gml look like:
<gml:featureMember>
<AX_Flurstueck>
<position>
<gml:Surface srsName="urn:adv:crs:ETRS89_UTM32" gml:id="KS6">
<gml:polygonPatches><gml:PolygonPatch>
<objektkoordinaten>
<gml:Point gml:id="KSE"><gml:pos
srsName="urn:adv:crs:ETRS89_UTM32">476659.545 5775519.378</gml:pos>
</gml:Point>
</objektkoordinaten>
and the changed gfs:
<GMLFeatureClass>
<Name>AX_Flurstueck</Name>
<ElementPath>AX_Flurstueck</ElementPath>
<GeometryType>3</GeometryType>
<GeometryElementPath>position</GeometryElementPath>
Thanks in advance.
Ralf
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100727/2c4b1c12/attachment.html
