[gdal-dev] RFC 29: OGR Set Desired Fields
Tamas Szekeres szekerest at gmail.com
Thu Jul 29 12:49:59 EDT 2010
Martin,
I didn't follow all conclusions made earlier in this thread, but I don't
think it makes much sense to enable/disable the special fields since those
are derived from the attributes of the feature instead of fetching the
values physically from the data source. For example OGR_STYLE corresponds to
OGRFeature::GetStyleString() which can provide a meaningful value even if
the styles are not handled/supported by a particular driver.
Assuming we only deal with the physical attributes it seems to me more
reasonable to store a flag in OGRFieldDefn which could be set individually.
In this regard each driver would do something like:
for( int iField = 0; iField < poDefn->GetFieldCount(); iField++ )
  if (poDefn->GetFieldDefn(iField)->IsIgnored())
    continue;
  // fetch field
This would eliminate the requirement to maintain a separate array of the
ignored/desired fields.
Best regards,
Tamas
2010/7/29 Martin Dobias <wonder.sk at gmail.com>
> On Wed, Jul 21, 2010 at 6:59 PM, Martin Dobias <wonder.sk at gmail.com>
> wrote:
> > So, in case there will be no further comments, I'll update the RFC to
> > match the API you've proposed.
> Hi Frank,
> I've updated the RFC to reflect your suggestions:
> http://trac.osgeo.org/gdal/wiki/rfc29_desired_fields
> Given that there has been no further discussion, can we mark the RFC
> as proposed and start the voting?
> Regards
> Martin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100729/13035bab/attachment.html
