[gdal-dev] Compiled gdal.lib v1.7.2 ==> doubled file size
Tamas Szekeres
szekerest at gmail.com
Thu Jul 29 18:36:57 EDT 2010
Yes it's possible. And if you compile the same for x64 it results even
larger files. But why is this important?
Best regards,
Tamas
2010/7/30 Paul Meems <bontepaarden at gmail.com>
> I've just compiled v1.7.2 of GDAL with VS2010, using an almost identical
> makefile as before with v1.7.1 (compiled with VS2008).
> The file size of the v1.7.1 lib file is 78MB and the lib file of v1.7.2 is
> 138MB.
> That is almost twice the file size? Is that normal or did I miss a setting?
> Thanks,
> Paul Meems
> The Netherlands
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100730/c90b7315/attachment.html
