[gdal-dev] Clearing OGR Attribute Filter on ESRI Personal Geodatabase
Fri Jul 30 09:54:56 EDT 2010
Joel Odom wrote:
> I'm encountering an issue where once I've set an attribute filter on an
> ESRI personal geodatabase, I cannot clear that filter.  If I pass NULL
> to SetAttributeFilter, the filter is internally set to "", which makes
> future queries return zero results instead of all rows.  Examining the
> personal geodatabase driver code, I find:
> OGRErr OGRPGeoTableLayer::SetAttributeFilter( const char *pszQuery )
>     if( (pszQuery == NULL && this->pszQuery == NULL)
>         || (pszQuery != NULL && this->pszQuery != NULL
>             && EQUAL(pszQuery,this->pszQuery)) )
>         return OGRERR_NONE;
>     CPLFree( this->pszQuery );
>     this->pszQuery = CPLStrdup( pszQuery );
>     ClearStatement();
>     return OGRERR_NONE;
> Around the line, "this->pszQuery = CPLStrdup( pszQuery );" should there
> be an additional bit of logic that sets this->pszQuery to NULL
> if pszQuery is NULL?  I've searched this mailing list and find no
> reference to this.  Is there a possible work around?  Thanks.
Joel,
Yes, I think you are right.  I imagine this:
should be replaced with:
     if( pszQuery )
         this->pszQuery = CPLStrdup(pszQuery);
     else
         this->pszQuery = NULL;
Could you file a ticket on this issue at http://trac.osgeo.org/gdal?
Best regards,
