[gdal-dev] S-57 Driver WRONG Geometry
ogr user
mrxonx at hotmail.com
Tue Jun 1 07:32:22 EDT 2010
If we assume that each S57 object corresponds to a real world entity -
in my opinion the best encoding would be a separate line object. I.e.
the main road is a point to point entity (as LineString supports) and
the spur from the east (such as the one from Ljubicevac) is a separate
line. That would make any current S57 decoder happy without resorting to
complex geometry.
--Mike
Bogdan Grama wrote:
> I guess is a commodity. The authority has sevencs production software.
> So, if it “looks ok” in that software “never mind the others”.
> Until Frank implemented the modification IÂ’ve recomposed myself the
> geometry. But there is no way other than visual to decide if I should
> draw edge by edge or a single linestring since there is no masking
> information available. :(
> Bogdan GRAMA
