[gdal-dev] Convert shp to gml file
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Jun 2 00:44:38 EDT 2010
Jim,
GML driver doesn't support reporting of the geometry type for the layer.
However, you will get the right geometry when you ask for the geometry
itself. Try "ogrinfo -al test.gml" and check the reported geometries.
On Wed, Jun 2, 2010 at 4:33 AM, jim hopper <JAMES.E.HOPPER at saic.com> wrote:
> Ok, I got gdal rebuilt with xercesc support, and I can read it with
> ogrinfo.
> But it says:
> Had to open data source read-only.
> INFO: Open of `test.gml'
>      using driver `GML' successful.
> Layer name: ford_plant_2d_bldgs
> Geometry: Unknown (any)
> But the original shape file does have geometry:
> INFO: Open of `ford_plant_2d_bldgs.shp'
>      using driver `ESRI Shapefile' successful.
> Geometry: Polygon
> Feature Count: 2531
> Extent: (370010.126533, 4337857.290364) - (372942.794685, 4341771.522431)
> Layer SRS WKT:
> PROJCS["WGS_1984_UTM_Zone_15N",
>    GEOGCS["GCS_WGS_1984",
>        DATUM["WGS_1984",
>            SPHEROID["WGS_1984",6378137.0,298.257223563]],
>        PRIMEM["Greenwich",0.0],
>        UNIT["Degree",0.0174532925199433]],
>    PROJECTION["Transverse_Mercator"],
>    PARAMETER["False_Easting",500000.0],
>    PARAMETER["False_Northing",0.0],
>    PARAMETER["Central_Meridian",-93.0],
>    PARAMETER["Scale_Factor",0.9996],
>    PARAMETER["Latitude_Of_Origin",0.0],
>    UNIT["Meter",1.0]]
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100602/d6fc9861/attachment.html
