[gdal-dev] Help with gdal_grid
Tim Robertson
timrobertson100 at gmail.com
Fri Jun 4 01:52:04 EDT 2010
Thank you very much Even,
Indeed Int16 makes Mac and Geoserver happy. Now I am on to the next
task which is assigning some colors.
On Thu, Jun 3, 2010 at 10:43 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> I'd be suprised that the produced GeoTIFF is "invalid". One possibility could
> be that Mac preview and Geoserver cannot handle 64bit floating points
> GeoTIFF, which is a far less common formulation than 8bit or 16bit GeoTIFF.
> Or that they have certain requirements (for example you could try to specify
> the SRS with -a_srs in case one of them requires it). I'm just guessing
> randomly. Best should be to ask the mailing lists of those software.
> Le Thursday 03 June 2010 20:31:28 Tim Robertson, vous avez écrit :
>> Mac preview and
>> Geoserver
