[gdal-dev] gdal2tiles.py reducing output png file size.
Hemant Bist hemantbist at gmail.com
Fri Jun 4 10:58:11 EDT 2010
I am tiling some geoTiffs by using gdal2tiles.py
Currently I am reducing the png file size using following  imagemagick
convert command. Is there some option in gdal2tiles.py that I can use to
reduce the file size (instead of forking a convert command for every tile )?
my convert command is: convert -depth 8 -colors 32.
(I believe) the  reduction in png size is mainly due to reducing the number
of colors in the png. Is it possible to do that in gdal2tiles.py either by
some option for output png, or by preprocessing input geotiff (gdalwarp?) to
have limited colors.
Best,
Hemant
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100604/3b99ad0d/attachment.html
