[gdal-dev] Calculate lat lon of image corners knowing center's
lat lon
Jayesh Chaudhary
aashishcy at gmail.com
Sat Jun 5 16:33:37 EDT 2010
Thanks for your reply. I think I have to gather more information here about
the projection of the image. Currently the meta data tells me only these 3
things:
1. Origin lat lon
2. Size of the image
3. Spacing
All I need is 4 corner points in lat / lon. Currently I am doing something
like this (as an approximation)
long = centerLong + pixel_x_relative_to_origin
Thanks
On Sat, Jun 5, 2010 at 4:20 PM, ogr user <mrxonx at hotmail.com> wrote:
> The answer is - it depends. If you know the image projection (Mercator?)
> and the precise scale of the image - it may be enough to have just one
> point (think - a tile from Google maps).
> To georeference an image in a general case (assuming the image has
> simple linear proportions) requires at least 2 (really at least 3)
> points (otherwise the system of equations won't be solvable) and more
> would be better. Once you solve it - you can get coordinates of any
> other points in the image.
> Aashish Chaudhary wrote:
> > Hi,
> > I have an image with center known in lat / lon. I need to calculate
> > the image corners in lat / lon. I have some idea but I am wondering if
> > someone can share his / her knowledge.
> > Also is there a utility in gdal that would do this for me?
> > Any help is appreciated.
> > Thanks,
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100605/4546000f/attachment.html
