[gdal-dev] Is a way to just get the minimum bounding polygon of
just the image.
keith lewis
lewis.milehi at gmail.com
Wed Jun 9 16:29:27 EDT 2010
John,
OSSIM has a command-line tool that might be helpful. It is called
"extract_vertices" and outputs the 4 corners of the true image data.
Here is an excerpt from the document -
Used to compute the valid vertices (corners) of an image. Defines a polygon
- inside the polygon are valid sampled pixels outside are nulls.
extract_vertices <image_file>
You may need to install OSSIM to get the command-line tools.
http://download.osgeo.org/ossim/
Keith
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100609/14302c27/attachment.html
