[gdal-dev] GDAL Speed Optimization
Iván Sánchez Ortega
ivan at sanchezortega.es
Thu Jun 10 19:07:16 EDT 2010
El día Thursday 10 June 2010 09:49:01, Stefano Moratto dijo:
> I use GDAL to download tiles (jpeg) from OpenstreetMap and to compose a
> bitmap of the area that is being viewed. The resulting bitmap (not
> compressed) is warped and displayed.
Hhhhmmm. Personally, I think you're doing it wrong.
If you really need speed for custom reprojections of OSM data, the best thing
to do is to render the data locally with Mapnik. i.e.:
- Download a planet file
- Put it in PostGIS via osm2pgsql
- Configure Mapnik to use the projection you need
- Use Mapnik to get the desired area rendered
You might incur in a speed penalty due to the rendering itself, but you
guarantee that there will be no artifacts due to the image warping.
And also, you might get a boost by reprojecting the vector data inside PostGIS
so Mapnik doesn't have to reproject it on-the-fly.
I realise that setting Mapnik is quite a lot of work at first, but it's an
idea that is worth considering in your case.
Cheers,
Iván Sánchez Ortega <ivan at sanchezortega.es>
Un ordenador no es una televisión ni un microondas: es una herramienta
compleja.
