AW: [gdal-dev] gdalwarp and GTiff creation option NBITS
Fischer, Andreas Andreas.Fischer at kreis-unna.de
Fri Jun 11 16:50:56 EDT 2010
Hello Frank,
thanks for your reply.
Can you let me know how to create a tiffinfo report? What tool do I need to do so?
Thanks und best regards
Andreas
-----Ursprüngliche Nachricht-----
Von: Frank Warmerdam [mailto:warmerdam at pobox.com]
Gesendet: Freitag, 11. Juni 2010 18:32
An: Fischer, Andreas
Cc: gdal-dev at lists.osgeo.org
Betreff: Re: [gdal-dev] gdalwarp and GTiff creation option NBITS
Fischer, Andreas wrote:
> Dear list,
> I try to convert a raster images (GTiff) with gdalwarp. The images only
> have two colors (black/white) and the color table just have two entries.
> Therefore the file size for each image is exactly as big as needed
> (1bit/pixel). The result of gdalwarps transformation are images with
> 8bits / pixel and 256 entries in the color table. The file size for each
> image  is increased but in this case this is without benefit, because
> the results are still black and white.
> So I tried the creation option “-co NBITS=1”. Color Table und file size
> are now exactly as I expected,  but I can’t display the result properly
> with any program. For example IrfanView does fine, but unfortunately
> MapInfo Professional doesn’t. MapInfo Professional just shows irregular
> stripes. After opening the result file in IrfanView and saving it as a
> copy, the copy is displayed in MapInfo fine as well. I do not understand
> this behavior, because gdalinfo doesn’t show any differences.
Andreas,
It would be helpful if you could provide a tiffinfo report for each of
the three files.  It should reveal more of the low level tiff format
details which will be needed.
Best regards,
Diese E-Mail wurde beim Ausgang auf Viren geprueft. Wegen der
potentiellen Gefahr auf den Uebertragungswegen wird zu einer
Vireneingangskontrolle geraten. Eine Haftung für Virenfreiheit
wird ausgeschlossen.
