[gdal-dev] ESRI file geodatabase support
Stefan Keller
sfkeller at gmail.com
Mon Jun 14 13:39:45 EDT 2010
Hi all
At ESRI Developer Summit, March 22–25, 2010, Palm Springs, CA, they
talked about the ArcGIS 10 to be expected in June 2010.
But somebody (http://tinyurl.com/34nk558, 19. April 2010, german) said
that the opening of the API (C++ only) won't make it into this
release.
But since this is a storage format I question what this will be good
for? I'm after an exchange format which is better than Shapefiles!
Yours, S.
P.S. Off topic proposal: It would be perhaps interesting to talk about
a new GIS format at FOSS4G2010? There will be a presentation
"SpatiaLite, the Shapefile of the future?" (the argumentats for it are
already layed out here, unfortunately in german:
http://www.fossgis.de/konferenz/2010/events/127.de.html )
2010/6/14 Peter J Halls <P.Halls at york.ac.uk>:
> Matt,
> although we were told at the time that the EMEA 2008 Proceedings would be
> put online, I've yet to see them or hear of the result - I was a speaker and
> submitted my materials on time and as requested and that seems to have been
> the end of the story.
> Peter
> Matt Wilkie wrote:
>> The earliest reference I found to a "promise" of an open specification for
>> file-gdb was ESRI UC 2006, with discussion where of a forthcoming public
>> specification mentioned as far back as ArcGIS 8.3.
>> In many discussions people seem to use the terms open API and open file
>> format specifications interchangeably. ESRI itself seems to be pretty
>> clearly sticking to API-only line though, from the 2007 UC:
>> "While ESRI would ideally like to open the file geodatabase format in a
>> manner similar to what we did for shapefiles when we released ArcView 2,
>> geodatabases are complex and can be easily corrupted outside the ArcGIS
>> environment. Instead, we plan to engineer a high performing and well
>> documented API that developers can freely embed in custom applications and
>> that will read and write file geodatabase datasets. This will be released
>> after ArcGIS 9.3." -- http://bit.ly/esri-uc-qa-2007
>> If you've a reference for talk of the file fromat spec though I'd love to
>> see it. Searching for (EMEA) User Conference 2008 shows a few announcements
>> for the event but no proceedings or blog reports; I'm likely not using the
>> right keywords.
>> I also echo the request for people attending *any* ESRI conferences to ask
>> about both a public file format specifcation and programming API to the file
>> geodatabase.
>> best regards,
>> matt wilkie
>> Geomatics Analyst
>> Information Management and Technology
>> Yukon Department of Environment
>> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
>> 867-667-8133 Tel * 867-393-7003 Fax
>> http://environmentyukon.gov.yk.ca/geomatics/
> Peter J Halls, GIS Advisor, University of York
> Telephone: 01904 433806 Fax: 01904 433740
> Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
> This message has the status of a private and personal communication
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
