[gdal-dev] Re: ESRI file geodatabase support
Ragi Burhum ragi at burhum.com
Fri Jun 18 11:31:25 EDT 2010
This is meant to be an export/import type of thing. So you won't be able to
"open" something in ArcMap and start manipulating it live using the
ArcMap/ArcCatalog tools. The other approach I am proposing would be OGR as a
seamless datasource that integrates with ArcGIS at the data access layer
level. It would be transparent to the other tools.
- Ragi
On Fri, Jun 18, 2010 at 5:49 AM, Peter J Halls <P.Halls at york.ac.uk> wrote:
> And ... I think I may have found the file geodatabase documentation
> promised ...  in the  online ArecGIS 10 documentation, Administrator
> Library, Architecture of a geodatabase, Geodatabase XML.  It would appear
> that, in addition to the XML Schema they published several years ago, the
> XML documentation has been augmented with a view to interoperability being
> achieved at the XML level.  So, maybe no, they have not published the binary
> structure but they may have published enough to enable XML exchange.  I've
> not read all the material - and I would need to think about much of it
> before I understood it.  Whether there is enough there I cannot say ...  I
> was looking at
> http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html
> Best wishes,
> Peter
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100618/35b19c8a/attachment.html
