[gdal-dev] Re: Copy coordinate system and corner coordinates
Chaitanya kumar CH
chaitanya.ch at gmail.com
Tue Jun 22 05:38:16 EDT 2010
The GDALDataSet class has methods to get and set such info. (
http://www.gdal.org/classGDALDataset.html)
The corner coordinates can be obtained using GDALDataset::GetGeoTransform()
On Tue, Jun 22, 2010 at 2:17 PM, canduc17 <candini at meeo.it> wrote:
> Well ok, but I don't have to merely copy the dataset.
> I have to eleborate it and after the elaboration I have to add all the
> information i can get from gdalinfo.
> So CreateCopy() doesn't fit for me.
> How to extrac ONLY these info and put them inside the new dataset?
> http://osgeo-org.1803224.n2.nabble.com/Copy-coordinate-system-and-corner-coordinates-tp5207721p5207848.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100622/353be794/attachment.html
