[gdal-dev] Can VRT be used to control display order of images in
mosaic?
Roger André
randre at gmail.com
Tue Jun 22 10:54:54 EDT 2010
Hi All,
I'd like to control the order in which overlapping images are displayed in a
mosaic. Is it possible to do that by using a VRT, and altering the order in
which the files are defined in it?
The online doc for gdalbuildvrt states, "If there is some amount of spatial
overlapping between files, the order may depend on the order they are
inserted in the VRT file, but this behaviour should not be relied on."
Not sure if this disclaimer is for the gdalbuildvrt utility, or describes
the generic behavior of a raster VRT.
Thanks,
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100622/65d4d6e3/attachment.html
