Chaitanya kumar CH wrote: > > Since you said that gdalwarp did not work, try gdal_merge.py with the > options "-n -332768 -init 0". > Thank you, this did the job! Nop -- View this message in context: http://osgeo-org.1803224.n2.nabble.com/Handling-nodata-values-tp5222453p5224997.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
