[gdal-dev] Re: Handling nodata values
NopMap
ekkehart at gmx.de
Sat Jun 26 07:24:01 EDT 2010
Even Rouault wrote:
> Yo say 'gdalmerge quits with an error', but you didn't mention the exact
> error
> message nor the command line you've used, so it is hard to tell what's
> wrong
Oh, that cause was obvious. Since the TIF had lost the georefence, there was
no overlap between the requested area and the TIF, causing an error due to
invalid size.
thanks
Nop
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Handling-nodata-values-tp5222453p5224999.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
