AW: AW: [gdal-dev] gdalwarp and GTiff creation option NBITS
Fischer, Andreas
Andreas.Fischer at kreis-unna.de
Mon Jun 28 11:41:32 EDT 2010
Hi Frank,
I'm sorry for my missing response yet. Nevertheless thank you for your helpful explanation!
But since it seems that there is no way getting gdal converted tif-files with creation option NBITS=1 properly displayed in MapInfo Professional, it might make sense looking for another shell program. This could work "in-a-pipe" and should convert a paletted gdal output file into a 1bit file without color table just IrfanView does.
Do you know a free software tool that will fit my needs? Or is there another way to think about? If the behavior of MapInfo Professional isn't default I could contact Pitney Bowes for sure as well. But I wouldn't rather wait for a solution from there ...
Thanks so far,
Best regards
Andreas
Mit freundlichen Grüßen
Im Auftrag
Andreas Fischer
Kreis Unna - Der Landrat
Zentrale Datenverarbeitung
Friedrich-Ebert-Straße 17
59425 Unna
Fon 02 3 03 27-44 16
Fax 0 23 03 27-28 96
andreas.fischer at kreis-unna.de
www.kreis-unna.de
-----Ursprüngliche Nachricht-----
Von: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] Im Auftrag von Frank Warmerdam
Gesendet: Dienstag, 15. Juni 2010 16:34
An: Fischer, Andreas
Cc: gdal-dev at lists.osgeo.org
Betreff: Re: AW: [gdal-dev] gdalwarp and GTiff creation option NBITS
On Mon, Jun 14, 2010 at 11:06 AM, Fischer, Andreas
<Andreas.Fischer at kreis-unna.de> wrote:
> Hi Frank,
> thanks for your hints. I could finally use tiffinfo very easily from FWTools-Shell, for I'm testing with a windows machine :-)
> b) File transformed with gdalwarp (gdal-file)
> TIFFReadDirectory: Warning, Unknown field with tag 42113 (0xa481) encountered.
> TIFF Directory at offset 0x10a8036 (17465398)
> Image Width: 11812 Image Length: 11812
> Bits/Sample: 1
> Sample Format: unsigned integer
> Compression Scheme: None
> Photometric Interpretation: palette color (RGB from colormap)
> Samples/Pixel: 1
> Rows/Strip: 5
> Planar Configuration: single image plane
> Color Map: (present)
> Tag 42113: 255
> c) gdal-file (b) opened with IrfanView and saved as a copy without changes
> TIFF Directory at offset 0x10a35bc (17446332)
> Resolution: 0, 0 pixels/inch
> Bits/Sample: 1
> Photometric Interpretation: min-is-white
> Orientation: row 0 top, col 0 lhs
> Samples/Pixel: 1
> Rows/Strip: 5
> Software: IrfanView
Andreas,
The most obvious difference between these is that the GDAL
generated file has a color table while IrfanView does not save
one with it's 1 bit output file. It would appear that some software
packages do not properly support paletted one bit files.
Unfortunately, because GDAL "sees" the min-is-white
input file as paletted it produces a paletted output file. I
cannot think of an easy way of avoiding this.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Diese E-Mail wurde beim Ausgang auf Viren geprueft. Wegen der
potentiellen Gefahr auf den Uebertragungswegen wird zu einer
Vireneingangskontrolle geraten. Eine Haftung für Virenfreiheit
wird ausgeschlossen.
