[gdal-dev] GDAL with OGDI
Frank Warmerdam
warmerdam at pobox.com
Wed Jun 30 02:33:42 EDT 2010
On Wed, Jun 30, 2010 at 8:00 AM, Chaitanya kumar CH
<chaitanya.ch at gmail.com> wrote:
> Paul,
> I think that the problem is with the SQL command built by the PostgreSQL
> driver.
> In the INSERT command a numeric field with the value NaN should be mentioned
> in quotes.
Chaitanya,
It might be prudent for the postgres driver to check for nan's, but it
isn't usual for OGR drivers to anticipate nan values in numeric fields.
>> It is the same with ogdi-3.1.5 and ogdi-3.2.0-beta.
>> why is hdh = nan (the corresponding hdp is correct), it works when
>> importing with ogr2ogr from FWTOOLS.
Regardless of what might be done to deal with the nan value, I think
there is an underlying issue to investigate, which is why a nan is
being produced by OGDI for a field that apparently has a valid
value.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
