[gdal-dev] Problems with gdalwarp re-projecting from lat-long to Lambert Conformal
Markus Neteler neteler at osgeo.org
Tue Mar 2 02:50:38 EST 2010
On Mon, Mar 1, 2010 at 7:12 PM, Bill Hudspeth <wbhk at unm.edu> wrote:
> When I try to re-project the exported AAIGrid to another projection, I
> use:
> gdalwarp -s_srs EPSG:4326 -t_srs '+proj=lcc +lat__1=33n +lat_2=45n
> +lon_0=97w' MODIS_output_latlong.asc MODIS_output_lambert.asc
Note that without -of format] you generate a GeoTIFF file...
> While the resultant projection information looks correct,
> Driver: GTiff/GeoTIFF
> The resultant text file has only the following on the top line:
... it is binary, not a text file. check
 gdalwarp --formats
for the available formats.
Markus
