[gdal-dev] Georeferencing Geostationnary (+proj=geos)
Frank Warmerdam
warmerdam at pobox.com
Tue Mar 2 14:41:02 EST 2010
Stéphane wrote:
> Hi,
> Does anyone know if Gdal, current version or development version, is
> able to translate from Geostationnary projection to other regular
> projection ?
> Is it planned in future Gdal release ?
Stéphane,
I can confirm that GDAL/OGR supports the geostationary projection
(+proj=geos in PROJ.4). You can specify the +proj=geos projection
strings with GDAL where it would normally accept proj.4 strings.
I see it translates:
+proj=geos +lon_0=42 +h=35785831 +datum=WGS84
as:
PROJCS["unnamed",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]],
PROJECTION["Geostationary_Satellite"],
PARAMETER["central_meridian",42],
PARAMETER["satellite_height",35785831],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0]]
I do not know how you would construct the geotransform
for an arbitrary satellite image though.
Best regards,
> 2010/3/2 António Rocha <antonio.rocha at deimos.com.pt
> <mailto:antonio.rocha at deimos.com.pt>>
> Hi Stéphane
> According to http://www.gdal.org/gdal_translate.html
> *-a_ullr* /ulx uly lrx lry/:
> Assign/override the georeferenced bounds of the output file. This
> assigns georeferenced bounds to the output file, ignoring what would
> have been derived from the source file.
> Yes... Regarding extracting sub-domains, I didn't tried
> Yes, please keep me in touch in case there are better methods
> Antonio
> Stéphane wrote:
> Thanks for feedback !
> Do you have any ideas of the meaning of -a_ullr arguments they
> gave you ?
> Futhermore, once you get your GeoTiff file, did you success to
> translate it to other projection, or extracting sub domains ?
> I've heard that GEOS projection is not so really supported
> currently by GDAL, and re-projection / sub domain extraction
> doesn't work correctly ...
> I'll keep you in touch if any news !
> Stéphane
> <mailto:antonio.rocha at deimos.com.pt>>>
> Greetings
> I had exacly the same problem. I have been using LSASAF data
> (from
> MSG-2nd Generation satellites) that provides LST and FVC in HDF5
> files. For some technical reason they are not goerreferenced and
> their information.
> I talked with a few ILWIS software developers and they gave the
> following Commands (adapted to my spatial coverage images):
> gdal_translate -a_srs "+proj=geos +lon_0=0.0 +h=35785831 +x_0=0.0
> +y_0=0.0" -a_ullr -924124.2 5421728.5 4179561.6 3468466.1
> "HDF5:"HDF5_LSASAF_MSG_LST_Euro_200802170100"://LST"
> "euro_area_georeferenced.tif"
> gdalwarp -s_srs "+proj=geos +lon_0=0.0 +h=35785831 +x_0=0.0
> +y_0=0.0" -t_srs "+proj=latlong" "euro_area_georeferenced.tif"
> "euro_area_latlong.tif"
> My HDF5 file doesn't contain any infoprmation regarding GEOS
> projection. So, I had to do this
> Hope this helps
> If you get any news/information/method regarding this, please let
> me know
> Best regards
> Antonio
> __________ Information from ESET NOD32 Antivirus, version of
> virus
> signature database 4907 (20100302) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> __________ Information from ESET NOD32 Antivirus, version of virus
> signature database 4908 (20100302) __________
> http://www.eset.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush | Geospatial Programmer for Rent
