[gdal-dev] faster way to display shapeFile
Frank Warmerdam
warmerdam at pobox.com
Fri Mar 5 16:05:13 EST 2010
Paweł Byszewski wrote:
> Hello,
> I have some map in ShapeFile and I am using OGR to display it. I folow
> the example od OGR website: OGR C++ API Read/Write Tutorial
> <http://gdal.org/ogr/ogr_apitut.html>(http://gdal.org/ogr/ogr_apitut.html).
> Unfortunately that way is very slow. I have map of whole country(only
> roads) and even when I try to display onlu one big city and I set
> spatial filter it takes very much times. Could you tell me if gdal/ogr
> has oportunity to read big files in faster way?
Paweł,
I get the impression you have a very large shapefile and are only wanting
to draw a subarea. I would suggest you spatially index the file and use
the SetSpatialFilter() method to fetch only features in the area of interest.
There is some information on spatial indexing for shapefiles at:
http://www.gdal.org/ogr/drv_shapefile.html
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
