[gdal-dev] pcidsk sdk svn:externals
Frank Warmerdam
warmerdam at pobox.com
Fri Mar 12 13:45:38 EST 2010
Folks,
For a few months now the gdal/frmts/pcidsk/sdk directory has been
referenced from the pcidsk sdk subversion using svn:externals in
GDAL trunk. This had the benefit of ensuing the latest pcidsk code was
always used with GDAL trunk. However, it has had some downsides too.
1) I tended to forget to update gdal/frmts/pcidsk/GNUmakefile when
I added files to the pcidsk sdk which was breaking the build.
2) When folks made branches, such as winkey recently did, it was hard
to keep the gdal/frmts/pcidsk/GNUmakefile up to date.
3) Each time I make a stable branch, like for 1.7, I need to futz
around to turn the svn:external into a local copy.
4) Evaluating the svn:external made my svn updates noticably slower
since they were done as an extra roundtrip to the server.
Anyways, the problem are not insurmountable, but on balance I think
the benefits of using svn:external are outweighed by hassles and so I
have gotten rid of the svn:external and done an svn copy of the sdk
into the GDAL trunk. I will refresh it periodically.
Let me know if anyone runs into problems or thinks this was the wrong
thing to do.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
