[gdal-dev] reprojection from BNG to WGS84 -- using gdalwarp
Mon Mar 22 13:14:09 EDT 2010
Andreas Joisten wrote:
> Hi all,
> I have problem to reproject a raster file in BNG British National Grid to WGS84.
> gdalwarp -s_srs EPSG:27700 -tps -t_srs EPSG:4326 -co TFW=YES -r near input.tif geo_output.tif
> I have some questions:
> Must be the input file a GeoTiff file?
Andreas,
No, gdalwarp will accept any GDAL supported raster format as input
as long as it has georeferencing.
> Which requirements must be met by the input file?
It must be georeferenced in some fashion.
> If the input file is a GeoTiff, do I need ground controlpoints?
By default gdalwarp will look for an affine transform, but I
see you have selected -tps which requires control points as input.
So yes, with -tps the input file would need to have 3 or more ground
control points.
Best regards,
